Are existing wall buttons / outside code keypads still usable when Wyze garage controller installed?
The installation video for the Wyze garage controller shows that the adapter takes the place of the wall button wires. Do the wall buttons become unusable or is there a way to keep using them with the controller installed? Do the outside key code pads still work?
The Wyze GDC is wired in parallel with the wall-mounted switch, so they both still work.
I don’t have one, but I believe an outdoor keypad connects directly with the GDO, so it should still work.
