TinyCam does what you’re looking for, but for Wyze cameras, it simply uses your Wyze login credentials and not the IP address. TinyCam will also display other brands at the same time using IP, port number, etc
tinycam has irked the hell out of me so far, it locsates so many channels, none of which are mine.
If you have 40 or so devices, w/o having to play unplug the device, how do you all discerne which device is a camera vs bulb vs switch vs appliance?
I also must vouch for pro. I have tinycam running on a firestick thats plugged into direct ethernet and I am able from any web browser able to view the cams perfectly without lag.
