Do you think there is a way to install the application to be tested without going through TestFlight? It would surprise me but I try the questionđ
App Version 2.13, Wyze Cam Outdoor Camera and Base Station, and Wyze Band Firmware Released - 9/9/20
You probably saw this already but thought Iâd drop it here for you in case you had not. I still have a spare iPad running app V2.8.20, hums right along and nice big event thumbnails. ![]()
Anyway, if youâre bored or need a chuckle ![]()
I have followed this thread at that time. I have kept the last iTunes on a laptop that would worked but I must use an ipa that was already on backup. We cannot take an ipa from someone because it is not come from your account. Thanks for the tipsđ
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
I have tried your beta application and the error 20015 is GONE. Your fix works perfectly. The beta asked me to update the firmwares of my cams but didnât do it. I donât want to have others problems. ![]()
I will use the beta application until the official released comes out.
Thank you very much for fixing it rapidlyđ
Edit: The beta has fixed my playback issues that happen with the new released. It happens frequently when I clic on playback, the cams freezes and rebooted by themselves. I have tried the beta with all my cams and I didnât not see this issue anymore. ![]()
Edit: I have tried the playback with the official released and I donât have the issue above. Have you change something on your side? If not, if it happens in the beta, I will tell you.
Edit: @Seapup you can installed it without TestFlight.
Latest 2.13 beta got rid of a latency issue I was having with cameras at one of my sites. Literally night and day performance. I think it was more the app than the .174 firmware update on my V2s.
I am unable to update outdoor camera firmware from 4.17.0.128. It fails multiple times in spite of power cycling both camera and base station. Base station was able to be upgraded to 4.16.0.168. Camera can be viewed live.
Thatâs good news! ![]()
New app version 2.13.119 fixed this problem , thanks wyze team
Ok my last whine regarding this. They fix this in a couple days but yet the no fragment errors have gone on since June that I know of. Logically I would think not being able to view videos on a paid cloud service would take priority over a scrolling issue. I see zero logic or common sense in that scenario. Is what it is.
Our apologies for the frustration! Weâre still looking into whatâs causing the fragment issues. Itâs a priority but the other ones were easier to bust out fixes for as we investigate the fragment problem with different teams.
I figured that Gwen, I just had to whine a little. ![]()
Thank you for the update. ![]()
Youâre welcome! Thanks for your patience and sorry for the necessity. ![]()
