App audio hangs after log out in beta on android
The in call audio channel from livestream in beta app gets stuck on. Using a galaxy s9+ on android.
It seems to prevent bluetooth audio from working properly until app is force shut down.
I would suggest using the media channel. Which is widly supported than in call audio.
Hello @sreagan, this is a known issue and the Dev team is working to fix it. You can do your part in helping by sending in log files from the Wyze app.
Here goes some instructions on how to do that.
