I’ve read through all the posts regarding outdoor mounting. Not a fan of the bird house plus it doesn’t seem truly weatherproof. Has anyone tried a generic “bubble” type cam cover? I should be able to access an eave mount fairly easily and route the cord into the attic for power so that’s not an issue for me. If anyone’s used a bubble, did you use clear or smoked and did one or either work/not work with IR and night vision?
Thanks
I’m going to assume that since it’s behind glass (or plastic) you will experience the same issue as others are when using this against a window if you use night vision.
I bought a dome for next to nothing from AliExpress following a suggestion from this community (thanks to that poster!)…as mentioned above, had to turn off the IR. I am planning on switching my Hue lights in their outside fittings to IR Lifx ones to solve the problem.
