Anyone knows what this error means?
I’m having issue recording in SD card and this is what I recorded from my Cam Duo Doorbell.
Anyone seen this error code before?
It is having trouble reading from the SD card. Try rebooting the cam. If that doesn’t help, you may need to format the SD card. If still problematic, time for a new SD card, that one is likely worn out.
If it is a new(ish) SD card, it may not have ever been formatted? Personally I like to run them through the SD Card Formatter utility from sdcard.org for the first format. After that, the formatter built into the cams seems to work fine.
