My Wyze cam v2 has a solid yellow light. I’ve had no success resetting it. I don’t have an SD card or micro to standard converter so that won’t work.
Welcome to the forum.
A reset does not require a micro SD. Just hold down the reset button for an extended period of time.
Reloading firmware would require a micro SD.
I’m sorry, I should have made it more specific. I tried that a few times. Thank you for your response!
No problem. Just wanted someone to address your specific issue. Hopefully someone will chime in soon.
I’m afraid that sounds like a bad firmware upgrade. Only way to fix it would be to do a manual update with an sd card. Any reason to not pickup a cheap card and reinstall the firmware?
