Anyone else having the “MicroSD Card Not Supported” message suddenly?
I’ve got 5 Wyze Cam Pan v3 cameras that are about a year old that are suddenly saying “MicroSD Card Not Supported. Unsupported microSD card detected. Do you want to format the microSD card now?” message. I try to format the SD cards using the app, but it says formatting failed. I figured that since the cameras are a year old maybe the SD cards have just gone bad (which is frustrating because I used good, expensive, quality SD cards!), so I replaced the cards but I’m still getting the same error messages.
I’ve tried formatting the SD cards using my computer following the instructions on the Wyze Website and I get the same errors in the cameras.
I also have 5 Wyze Duo Cam Pan cameras, 5 Wyze Cam Floodlight V2’s, and 2 Wyze Doorbell V2s that were all installed at the same time and I used the exact same Micro SD cards and they’re working just fine and don’t give that error message.
Take a look at other recent threads, it does appear the newest firmware is much more strict about SD card quality/issues. Nobody is 100% sure at this point what the exact issues are with some panv3s and certain cards, I (and others) suspect it is a mix of various different problems.
It may be your cards are fine and the firmware is an issue in your case. You can try downgrading to a previous firmware (the last downloadable one is from earlier this year) and see if that changes anything.
I typically wait a few days after new firmware comes out to see if there are any reported problems, then upgrade one cam for a few days, then do others. In this case, none of my Panv3s had any issues with this firmware, not exactly sure what the “magic combo” is that seems to be causing some people problems.
Yes, I have had a ticket open for 43 days with Wyze. The “say” it’s a priority, but I get crickets. It started after the most recent firmware update, and they will not allow me to revert to the previous one. Very poor on Wyze’s part.
I had issues with my SD cards when I first set up my new Wyze cameras. With the cost of quality SD cards being so high (in the clouds) I just went with the cloud subscription and eliminated the card issue. The cloud recording is pretty cheap and seems to work well so far for me.
I am having issues with my Floodlight V2 cam. Tried several SD cards and they work for a while and then say no available video at this time. @carverofchoice are you aware of this?
I haven’t heard of floodlight v2s doing this exact thing. There are some reports of SD card issues in some cameras like the pan V3 lately, and I know Wyze is looking into SD card issue reports right now. Most reports I’ve seen lately have been from people reporting that their SD card got corrupted and stopped working entirely. You are reporting that yours is not getting corrupted, it is working intermittently where it works and then stops and then works for a while and then stops for a while again. I hadn’t heard of that yet before I got your call tag. I am keeping an eye out for reports of SD card issues though since it’s a big topic recently and Wyze said they are looking into it.
Well, I’m not sure. They may be corrupted. This started happening about a month ago. I thought my first card got corrupted. It was working fine and then it wasn’t recoginzing it anymore when I tried to do a playback. Got the message “No available video at this time”. Thinking the card may be bad, I ordered a new one and installed it. Heard the “ding ding” when the card was installed, pulled up the camera and could see it was recoding to the card. That didn’t last long, maybe a couple of hours, and then back to “No video available at this time”. So again, ordered another card and same siutation. Ding ding, worked a little while and then back to the message on the playback. The weird thing is under the MicroSD Card settings on the camera it looks like it’s there and recoginzing it. But when you switch to playback, same darn message of no video available…
Where are you getting the cards from? Recording for a while then failing is a sign of a fake card (which with prices the way they are, have gotten extremely common). Could be an issue with the camera too, not ruling that out, just starting with the obvious.
The image you shared does have me concerned that it isn’t at least Standard 32 GB. A lot of cards that use less than 32GB now are using substandard quality silicon scraps that tend to fail pretty easily. As Dave said above, a lot of scammers are using scraps and putting them into cards with fake firmware that makes it look like it is a larger or good quality card, and will sometimes even put a real brand name on them And then sell them on Amazon or Groupon or the Chinese based suppliers, etc. Wyze cams have not been handling that kind of cheap SD card very well lately, And they’ve been flooding the market because of the price extremes lately. I’m not necessarily saying that’s the case for you, Just that I noticed you have an extremely small SD card, and it’s been happening a lot to those, So I’m mentioning it just in case it’s related.
Other than that, Wyze is investigating SD card issues right now. We are waiting to see if they find out or announce anything.
What is in there now is a 64 GB, at least that’s what it said on the outside of the card.
Before this one, I bought a 256 GB. When the 256 GB quit, I thought maybe it was too big so I went down to a 64 gb. I bought them at 2 different places.
WYZE doesn’t sell SD cards anymore. Is there a particular brand either of you recommend? @dave27
Samsung Pro Endurance
Sandisk Max/High Endurance
Samsung or Sandisk “middle of the road” cards (like evo select etc)
Lexar
Western Digital (I have not used these personally, but they seem decent)
PNY
The first two will stand up to continuous recording. The others will as well, but no way to say how long before they go bad, and that use won’t be covered by their warranty. So those would be better for event-only recording on cams that don’t have tons of events.
The other important thing is to buy direct, either from the company themselves, or if you use amazon, make sure it is “shipped from and sold by” amazon, not a 3rd party. If it arrives with a white sticker with barcode (3rd party stock) send it back. Buying from a reputable brick and mortar store is an option too.
Thank you so very much for your help. I never knew there were “fake” sd cards but apparently that’s what I’ve ended up with. I really appreaciate the guidance!
I have one cam in my garage with a 64GB card that is set to record events only. It has 59.61 GB of usable capacity. A 256 GB card is not to big, I am using five of them. But you may need to mortgage your house to pay for them, The Samsung Pro Endurance cards are now $135-$153.00 US Dollars each. A 64 GB or a 128 GB will work just fine depending on your needs.
Definately sounds like I got a “fake”. I never knew about those. Lesson learned and I appreciate your input and guidance. Will definately make sure I get a correct one from now own.
