Android Version 2.5.36 Released!
Hi @HDRock, is the 2.5.36 lag the same you were experiencing in V2.5.28 with the Nexus 7 (2013)? Have you tried running V2.6 beta on it?
I’ve been hunkered happily with 2.5.28 but the features of the upcoming 2.6 are some I’ve been waiting for so I’ll be dipping my toe into that update.
I didn’t test V2.5.28 on that device, I jumped from V2.4.82 to V2.5.30 then V2.5.36
I haven’t tested beta V2.6.33 but I will , I’ll let ya know
Thanks!
Beta app V2.6.33 on the Nexus 7 tablet Android V6.0.1 , there really isn’t much lag at all , maybe a second , firmware is V4.9.4.169
Tested with All cameras in HD mode , individual cameras , not multiview
At first, I was having trouble with the camera I was testing with , lag time was inconsistent and not very good , anyway , found out I had a power problem with that V2 camera that is wearing the sensor bridge.
Testing lag time on a couple other cameras including one pan cam and as I said not much leg at all.
If you wanted to run 2.5.36 or Beta V2.6.33 you should be good
Good news, HD, thanks a bunch! :slight_smile:
Appears newest update fixed my Lag problem. Good work Wyze team!
Are you running an oldie, too?
Latest beta on 5 new V2’s bought on Wyzeday. device is a Samsung J3, A7.1.1, all on a relatively fast network , 10 plus down and up. I’m getting a 6 to 20 second lag when I wave my hand in front of the camera, evidence of dropped frames.
Performance used to be FAR better, < 3 second lag.
Obviously I need to get another phone :frowning: It looks like I’ve got to spend $100 which would have bought 5 cams.
But when will Wyze do another “upgrade” and make the next phone obsolete?
/edit - tried FW .169, .108 and the latest two. All had significant lag.
Time to break out the Reolinks :frowning:
Sorry didn’t answer earlier. I use a Droid Turbo. A few years old for sure but I really like this phone.
Tried it out:
