The landscape screen ratio problem is still there for Samsung S9/S9+ with 18.5:9 screen ratio … please fix … I previously sent a couple screenshots for app v1.5.31…
I can’t add a new device in the new update. The app freezes when I tap “yes, I heard ready to connect”. I had to remove myself from the beta program and install the public app and it worked fine.
While in the public app, my V2 which has been having connection issues was running at 228KBps and not having any issues. Upon returning to the beta app, the connection now drops continuously with a high speed of 32KBps every 5-10 seconds or so .
I can’t replicate the issue on my android device. The camera was added successfully. Could you try with your beta app again? If it fails, please send me an app log.
Here are the instructions to send us your app log:
In the Wyze app, go to My Account -> Help & Feedback -> tap Feedback at the bottom of the page.
In the Issue field, enter your ticket number if you have one already, otherwise name appropriately. In the Details field, please enter a brief description of the issue you’re having. Make sure to leave the box checked next to ‘Log file will be sent to the R&D team to help investigate your issue’ option at the bottom of the form and tap Submit.
I can confirm that the issue of the app freezing is gone after reinstalling the beta. My connectivity issues are still going though. Only with one specific V2. My other V2 and Pan are fine. And as stated before, on the public app, there is no connectivity issue.
