Are you doing just a quick single press on the Mic/Alex (depending on your remote version) button?
it comes up on my fire cubeâŚbut cams wonât load⌠my fire stick is one of the old ones and it doesnât come up on itâŚ
Have you added the Wyze Skill in your Alexa App?
Check to see if there are updates for the FireStick? I am not sure if the function is limited to a specific model though.
I think Iâll just stay with TinyCamPro⌠itâs difficult yet EASIER~~~ thanks for the help!!!
Finally!!! Thanks for postings. Still a little buggy. Mine dumps me out after a couple cameras. Its an old firestick i tested on. I need to try one of my 4k sticks. It could be a memory issue.
Just to add, the Wyze Webview also works well with my V3Pro and V3, with the Silk browser on the 4k Max Firestick.
(The log in/captcha screen can be a little finicky though).
I use a NUC cheap pc running windows 11. I run the Wyze android app 3 time on it, side by side, to view all my cameras at once. I stream this to my TVs. Work wonderfully so far.
