doesn’t work, it keep saying “Ready to connect”
My cams stopped working as well. I usually update them not at same time.
One day I updated camv2 and solved it after hours by using a different USB power supply. 5watt Apple adapter.
Not knowing what solved it i struggled with my pan cam that experienced the same problem after upgrade.
When i connected it to another spare 5watt Apple adapter it worked again. No more error 90 disconnected .
HI @boydehann and welcome to the community.
Thanks for that interesting observation, using a 5-Watt power supply vs the Wyze 2W. Perhaps @UserCustomerGwen might have that phenomenon examined by engineering. ![]()
Somewhere online it says:
" The power consumption is between 2 -4 watts , depending on whether night vision is turned on"
IF distance is a factor, isn’t this a sound adjustment to cover the voltage drop?
Mathletes, Electricians, Knowers & engineers please comment.![]()
