All of my sensors, motion and open/closed are showing offline. I get nothing out of any of them. I have two motion and two open/closed sensors.
Usually that means the bridge is having an issue. Try power cycling the camera the bridge is connected to. Also double check the bridge is not hot to the touch. Mine got really hot once. I unplugged it waited about 2 hours and reconnected it with no issues.
Thanks for the suggestions. I will try that
