All my SD cards are now corrupted / not able to be formatted
Note: If I try this on my Android phone it works now. I think in the past I had issues with my phone too. I was trying the below actions today using the emulator BlueStacks and maybe that is the issue but I am not sure it is.
My SD cards show that there is recording but will not show the video or it takes a very long time to play.
Very annoying.
I am now trying to look at a V3 camera sd card and it shows only one hour of video available but it is full and 128GB.
Please fix this bug.
I have the same issue here… 30 cameras with the same problem… horrible! What can i do?
You’re saying all 30 SD cards are now corrupted, at the same time? Wow the odd of that happening. Lightning strike or flood involved? Was there a major event in your area?
Same here… SD Cards failed… Reformated in a different machine, and the card are good…
The 128 GB micro SD cards I use cost $20.00 each, I’m glad I don’t have 30 cameras. :grin:
The 256GB cards I have now cost about $28.00 each, glad I previously got some on sale.
In the last 2-3 months, 6 Wyze Cams (v2, v4) have ‘eaten’ their SD cards (32gb, 64gb, 128gb). My lone v3 wyzecam seems to be okay so far. any fixes from them yet? I’m not wasting more $$ on new cards.
I have all kinds of Wyze cameras except for the V1 and the original outdoor cam. I really have no SD card issues except for one micro SD media that physically failed and that one came from Wyze.
Maybe the SD card slots are getting moisture/dirt inside or the camera is losing power while writing to the card?
I’ve never had a WYZE Cam eat an SD card in the last four years. Four WCO v1 all outdoors in the mud and rain recording to the SD via scheduled recording, 6 V3 cams all outdoors recording continuous, one V3 Pro outdoors recording continuous and 3 V4 cams all outdoors recording continuous. I guess they don’t like Korean Kimchi flavored Samsung micro SD cards. I :two_hearts: Kimchi. :laughing:
Likewise. No micro SD cards destroyed on my watch since 2019. Use the same 32GB ones when I purchased the cams. Did buy a 128 GB for the v4.
I don’t buy endurance cards, just reputable cards. No Wyze micro SDs purchased.
I have v2, v3, v4 and OG, but all cams are inside.
I have now joined the club. Sandisk Ultra 32GB, unable to format. Had the V2 Floodlight for over a year with the same SD card and now it’s stopped working. I have done everything but a factory reset. @carverofchoice do you have any updates on this?
Have you tried formatting the card on a PC? Don’t use quick format. Or tried another card?
No, I just came home to this and no computer here and I don’t know how to format it on a computer. I don’t have another card. It was working fine before
Do you have an adapter for your phone? You might be able to format on your phone.
No I don’t. I thought about trying to put it in another cameras and see if it would format that way.
Good idea.
Hey guys,
  • AVOID SanDisk Ultra SD Cards. Slow, overheat and highly unreliable. I’ve had more clients have problematic Ultra cards than any other.
  • Look for more reputable cars designed for high frame rates: Samsung Pro Plus (or “Ultimate”) series; SanDisk Extreme & Extreme Pro (Samsung + SanDisk lifetime warranty); or if you have the extra money either SanDisk High (or “Max”) Endurance (2yr Warranty, 100/30 R/W) or better / quicker option Samsung Pro Endurance (3-5yr War, 100/40 R/W) <<—— Best Choice! :warning:
  • Do note that just because an SD card is “U3” does not necessarily make it better. Aim for a card designed for high frame rates (cameras, dash cams, video recorders, SLR cameras, action cams, drones, etc). You are much less likely to have issues.
To be honest, I use Extreme Pro ($7 extra for “Pro” on Amazon) cards in motion recording cameras, and Samsung Pro Endurance for dashcam or 24/7 recording cameras.
Disk Formatting
Format your cards in the camera / dashcam / etc. first… If this does not work, use another camera or mobile device. Do not use your PC to format unless you are having issues with recording and you have tried debugging network related settings (not a streaming issue).
If you are using your PC to format, use something like Disk Management for greater control. Turning off “quick format” can also resolve flash memory issues.
Verify specs & Benchmark.
Check if your card is “V30” rated (30fps at FHD to 4K (supposedly)). You can also use a Flash memory benchmark app (phone or PC) to compare its performance to other cards you have spare.
Wyze Feedback & Bugs
From the “coincidental” reports and complaints all over the web, its fairly obvious in most cases a firmware update has affected the cams.
Put your complaints and feedback in writing!
The best thing you can do is directly email Wyze support with all your complaints in an organised and detailed manner, including: dates and times, exact model numbers, and specifying the SD card make and model (or state as bundled free card) in use. Make sure to state no new hardware had been added to the network, no charges or equipment was moved, etc.
The only way to get these issues resolved is by reporting them. Wyze DO NOT monitor these forums.
Good luck!
I always thought it was a good idea to format the card where you intend to use it.
I also strongly advocate for endurance cards. I’ve never experienced a hot sdcard, but rarely do continuous recording on any cams. Admittedly, I have used SanDisk Ultra cards in my Wyze and dash cams and none have failed. I now have switched all to 256gb high and up endurance (for overwrite protection) except for 2 BCP’s still ultra 256, that will probably not start overwriting for 3 or 4 years due to limited recording demands. Those BCP’s are also powered off for several hours in a 24 hour cycle. Quite an expense for 20+ cams and their backups.
If only doing smart events recording and limited hours in a day, I wouldn’t suggest a total ban on using the ultra card. Should be on an individual case by case scenario review.
Thanks for sharing mate.
I just wish that smarty-pants developers would create a hybrid mode!
Why can’t I have event recording during the day and continuous recording over night?
If you want me to pay a subscription, offer some professional grade functionality that can actually cater to people’s needs! :winking_face_with_tongue:
Yes, you’re spot on. They really need this information pinned as I can already see 4 other topics that should be merged or just linked to a resource to answer the question.
