I have three outdoor cams, a door bell and an indoor cam which is plugged in.
Yesterday all three outdoor cams went offline. The other two are fine.
I took the driveway cam down. Turned it off. waited. Turned it on. No luck
I tried to pair it again. Pairing is in progress. Please wait. Wyze cam outdoor setup failed.
I rebooted the router. No help
I deleted it. plugged it in to the base station. Pressed setup. Nothing happens.
I tried the sync setup with another of the outdoor cams, Wyze cam outdoor setup failed.
This is this is the first problem I have had since changing the router months ago.
What can I try now?
