On my firetv I can view my wyze cams but I can’t talk. On my ring cams I can press the mic button on my firetv and talk thru the camera. Wyze cams are not really Alexa compatible. If they were I could answer the door from my TV.
Sounds like a nice feature. Be sure to upvote your suggestion. ![]()
Voted. Sigh, yet another wish that would be solved simply by having a Firestick compatible version of the Android Wyze app, even if it needed sideloading. Really counterproductive for Wyze that the only thing that comes up when searching for Wyze on Firestick is the TinyCam app.
If you have Alexa (and you do if you have a FireStick, really no need for the Wyze app. Supported natively as a “skill”:
Yeah not good enough. Takes forever to launch, only one camera at a time, lag, no features, and it shuts down after a few minutes.
Got it. Was just a suggestion, as many do seem to be aware.
But yes, a true and dedicated app for the big screen would be awesome.
