Anyone having luck getting the plugs to work with Alexa skill?
I have a bunch of devices and a bunch of cameras all work with Alexa and the Wyze skill EXCEPT the plugs. I have the plugs working with the Wyze app, but Alexa will not find them.
I didn’t have a problem with them at all , Alexa found them as soon as I set them up , I have the plugs in some routines and everything works perfect
Alexa and my plugs work together. However, I had to disable and re-enable the Wyze skill before it would work.
Thanks! That did it! Geez Wyze that is not real cool.
I was pulling my hair out until I tried this. Disabled the Wyze skill in the Alexa app and then re-enabled it. The plugs were discovered right away. Thanks.
