I’ve tried unsuccessfully to integrate my Wyze plugs with Alexa. From the Alexa app, it will not find the plugs even though I was able to add them to my Wyze app with no issues. They function as they should from the Wyze app but what can I do to get them to work with Alexa?
Yes, I have downloaded the skill. Will not locate the plugs.
After I received and added my plugs to the network, I had to disable the Wyze Skill for Alexa and re-enable it before my plugs were actually usable.
Sorry, I should have been more clear. I have also signed into the app as well and the skill shows linked.
Hmmm, well I admit to being stumped. Linking was painless for me and worked first time. I think your next step would be opening a
I’ll give that a try
Disabling and reenabling the skill worked. Thanks for the tip.
Thank you, Wayne Luke! After hours of frustration, disabling and then re-enabling the Wyze skill finally allowed Alexa to recognize the plug.
Ran into another issue last night trying to add another plug. The process would not go beyond step 4. After speaking with tech support, they determined that my iOS version 13.1.3 was the issue. Upgraded to 13.2.3 and was able to add the plug successfully.
