Wyze plug will not connect with Alexa app. This is only Wyze product that will not repond to Alexa app. Deleted plug and reinstalled also reinstalled Alexa app
Disable the Wyze skill in the Alexa app. Then re-enable the skill and let discovery run at the conclusion. Of course make sure your plug is powered up and visible and controllable to the Wyze app first.
Reinstalling the app is not the same as re-enabling the skill.
They reset all Alexa security tokens yesterday as a security precaution. so you may need to re-enable the skill, as @rbruceporter suggested. Here’s how to do that.
I had this problem on android. Found that I had to turn off “personalize Skills”
