I just bought a second cam v3. How do i get it to connect with my account?
Follow the setup procedure. Should be on quick start guide that came with the camera.
- Open your Wyze App.
- On the Home Tab, tap the + sign on the top left of the screen.
- Select Add Device
- Select Cameras
- Select Wyze Cam V3
Follow the rest of the steps the app tells you to do. ![]()
Its saying ready to connect. I dont know what to do. Guide doesnt say. Its been a while since i set up my first. I remember having to scan qr code. Please baby me.
Thank you very much carver!!
Let us know if you need more help brendaJo. Hopefully you can get it from there.
Good information here.
https://support.wyze.com/hc/en-us/sections/360011231672-Wyze-Cam-v3
HelloYesterday I changed the password to my wifi so my neighbour who hacks into my electronic equipment used that to block my Wyze cameras. I ended up restarting from scratch to get my cameras connected again and enter my new wifi password. I had Cam Plus on them but now it needs to be reinstated.
Can you please handle this for me and confirm? This was at 4am.
Thank you.
Brenda Billard
@brendaJo I do not work for WYZE, I am just another camera user like 99.9% of the people on this forum.
Open your WYZE app, on the bottom right side tap account > on the next window tap services then tap Cam Plus and see if you have it, it will look like picture below:
