About the Wyze App category
Apply yourself here to create and discuss topics about the Wyze Application. Android or iOS, this is the place to talk about the Wyze App for stuff that doesn’t relate to any particular Product or Service.
:black_cat:
Perfect! Great idea.
I have been relying on Google Play reviews, which I take with a grain of salt, due to some ranting w/o good information. But I do check them before installing.
It will be nice to have a thread here from users that have some useful information hopefully, to their good or bad comments and issues.
Wyze App 3.0 on iOS iPad 8th gen. Seven cameras selected on ‘Devices’ list and taped on the star which added them to the ‘Favorites’ list and shows them on the initial page. EACH camera preview TAKES UP 1/2 the screen. CAN ONLY SEE TWO previews and must continue to SCROLL down to the others. Can the HOME PAGE be arranged in THUMBNAILS or smaller ICONS or GRID like prior version 2.50.9??? How are we expected to preview with constant scrolling? As with the prior version, if I wanted to see a bigger image I would just then open the THUMBNAIL. I don’t need all the camera “LIVE” each time I open the Home page. Please advise. Thank you.
How do I shut light strip off??? Now I have to go in to device. I click off. 3 seconds later it comes back on.
The latest update v 3.7.6 (699) No longer has the easy to use playback. They took away the 30 second jump feature. Way to go guys?
I would like an update that allows different notification sounds for each device on iOS. In particular, with the doorbell camera, I would like a notification sound option for the app when the doorbell is rang that is separate from the movement/sound detection notification. Thank you.
The virtual call setting does not work correctly. Specifically when the doorbell is rang, it doesn’t activate the microphone and it refreshes the camera feed.
Or perhaps it might help if there is the option of verbal announcement of the camera notification.
When I hit EVENTS the app shows me a set of all events, like motion. Then I’ll tap on a specific event. The system then opens that event but when I tap the SD icon, a message says “no video available at this time”.
However, I ABSOLUTELY KNOW there is video and now the app will not even play it from the SD card
please FIX THIS!
why can’t I download app to my pc?
why can’t I download the app to my laptop to share?
