Sure but the ones I have do both, so I prefer to have the flexibility and fallback. I don’t have to use the local controls unless I want to. The app (and Alexa) work fine.
Smart Outdoor Water Facet Controller
Does anyone else have a bad habit of turning on the outdoor water facet to water their foundation with a soaker hose, and forget it’s on for a day or two? I may have done just the several times last month and it resulted in a water bill almost $500, when it should have been under $100.
I have the Wyze Sprinkler setup and I love it! What I really need now is a Wyze smart device to connect to each water facet, around my house so I can connect them to soaker hoses, which will water my flower beds and the foundation of my house during the peak of the summers. I’d love it if it could also work with the Wyze Sprinkler, to be added as an additional zone, per device. This would save me time and money, as well as save my homes foundation so I don’t continue seeing cracks in my walls.
Sprinkler master valve manual trigger
I have a hose bib on my sprinkler line. It would be great to be able to activate the master valve to allow me to use the sprinkler without another zone…
I want to get the sprinkler system but I need a few hose zones like this Smart Water Timer for Hose from B-hyve (with Wi-Fi Hub) – OrbitOnline
I want it to talk to the main controller tho not WiFi for better battery life I still need a main wired controller
My current Bhyve is garbage
They do act as the hub to the hose timers yes
No they don’t! That is why, unfortunately, I also had to buy the WiFi to Bluetooth adapter. See my July 2021 post above.
My bhyve controller acts as the hub on mine. I use the newer controllers that have it built in like this one products/b-hyve-smart-indoor-irrigation-controller Part #: 57925
I’m using it right now. It just doesn’t work well
I wanted to move to wyze and hoped they’d add hose timers but it looks like they only want to censor my links so I’ll find someone else.
Welcome to the Wyze community MrWisey. Wyze does not censor posts unless they violate the Community Guidelines. Your posts with external links were flagged by the forum software as potential spam, hidden to the public and held for moderation. This occasionally occurs when certain criteria are met; in your case, as a new forum user, posting the same external link in more than one forum location within a short period of time. As you are no longer a new user, you should not encounter this issue again, but please avoid crossposting the same content in multiple topics.
