You already have a Sprinkler Controller, can you make it so that it controls the sprinklers via Wi-Fi?
Please make sure you Vote for your Post as the system does not automatically add one for you
For Clarification, the requester is asking for a product which will allow for WiFi Connectivity to remote controllers / Valves from the primary Wyze Sprinkler control. This would allow for controlling an irrigation system from one primary controller talking to the Remote. This could eliminate the need to run wires to the Primary Sprinkler Controller.
@4960a4e40e9f741b6834 , Please provide further clarification to your request if you feel it is needed.
Basically I would like to have your sprinkler controller operate the sprinkler control valves remotely via a Wi-Fi connection instead of with wires.
