I just got a notification to upgrade the software on my Cam. I’ve tried three times, and I keep getting a message that the upgrade fails. Any suggestions?
- How far away are the cameras from your router?
- Is your phone/tablet on the same WiFi network?
try:
power cycling
manually flashing firmware.
Thanks for the quick response. I power cycled the camera, and force stopped the app. Restarted both and the update was successful. Thanks again!
Glad it worked out for you!![]()
Don’t feel lonely!
Check out the number of complaints on Facebook.
My Pan Cam has been operating perfectly. I think I’ll skip the update for now.
It only took me an hour to get my cam pan to upgrade to FW 4.10.6.156. It failed multiple times before I succeeded. I thought about running over it with my truck a few times. ![]()
Mines is failing multiple times too, even after unplugging for 10 secs. I updated the software to the latest from the App Store, the cams rotated, firmware update failed again ![]()
