I used the included 3M adhesive tape on glass to mount my WyzeCam but now want to remove the tape, but it’s stuck on pretty good. How can I remove it? Wish I’d used those Command strips instead.
You can try rolling it with a finger. If that doesn’t work, then a single edge razor blade will work very well on glass, followed by some Goo Gone to get the last residue.
I can’t roll it with my finger because the metal disk is over it.
Ah… use a piece of dental floss to “saw” under the disk to get it off. Then remove any remaining tape as above.
Yes, dental floss or fishing line to saw it off… also see the 3M tech bulletin:
