3D Printable Duo Doorbell Angle Mount for vinyl siding
I designed a wall mount for my new Duo Doorbell. Sharing the files in case you want to print one too…
https://www.thingiverse.com/thing:6821098
Enjoy!
Very cool!
Vinyl Siding Mount
  • Straight
  • 10°
  • 15°
  • 20°
  • 30°
Can mirror to allow left or right angle.
I saved this to share with people.
I dig stuff like this and learned about 3D printing within the past year just so I could fabricate an angled mount for my Video Doorbell v2. Thank you for sharing your design with the community, @t0n3!
Amazing thanks so much for this! Would it ever be possible to make a design flat siding, but at larger angles for tight spots ?
The corner my doorbell wire hangs out is 1.6" wide at 90 degrees so my only option would be to put a peice that is 1.6" in the back and it curved at an angle so it can fit.
For the sake of anyone else finding this post here, I updated the original link with a few additional models for flat wall mounting and angles. Hope this helps!
