Can I use a 3 outlet adapter on the Wyze plug to connect outdoor lights?
Yes, as long as the overall amperage is at or lower what the plug can supply, 15 amps.
Great thank you very much.
Any news or info on the outdoor camera?
Thanks
Hold on, the plug itself isn’t rated for outdoor use, is it?
Correct, the plug is only rated for indoor usage
Thanks. Forgot to respond to MelQ - the big announcement is almost certainly the release of the camera. Hang tight.
How is that going to help power his outdoor lights?
It’s not, but it tries to answer his or her other question above.
Gotcha.![]()
