My 2 cameras aren’t close enough for an easy daisy chain, but could I run 2 cameras on this USB power adapter?
Tranesca Dual USB Wall Chargers- 2 Pack (White) https://www.amazon.com/dp/B07DR982YB/ref=cm_sw_r_cp_apa_i_scosCbX4YBA2K
You need 1amp for a V1/V2 and 2amp for a Pan Cam. I don’t love the one you posted because it doesn’t specify the power for each port (although I’m guessing the phone only one may be 1amp).
Here’s a better (and cheaper) one that will power 2 of either camera model:
I chose that one because of the plug on the end. I need that compact design where it’s going.
Will 2.4a on a single port damage the normal v2 camera? I assume that adapter I showed is 1a on one port and 2.4a on the other.
No, 2.4amp is okay for either camera. So if you are powering V2 (not Pan Cam), then the one you chose should be fine.
