2 cameras one usb with splitter at end for power?
I want to run one usb cable, 25ft with a splitter at the end to power 2 cameras close to each other. Will this setup work?
Welcome @JBRADY76!
What cameras will you be using? Are they inside or outside? Will daisy-chaining work for you?
wyze v3, outside under cover, daisy chain?
[Mod Edit]
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
I have two cam pan cameras connected with a micro usb y cable which is connected to a 42 foot long micro USB to USB cable. The cam pan cameras draw more amps than the v3 so the short answer to your question is yes.
So you have a 42’ usb extension cable going into a splitter to power 2 cameras? Thank you for your response.
@JBRADY76
Yes. No issues but the standard USB wall adapter that comes with the camera doesn’t have enough amps to power two cameras so I bought some Anker 4 port USB wall chargers.
Good additional bit of info, thanks
No issues on mine…
Do you remember where you got your splitter? Link? I see a couple in Amazon, but would prefer something already tested with V3s.
https://www.amazon.com/Key-by-Amazon-In-Garage-Delivery/b?ie=UTF8&node=21222091011&tag=cnet-buy-button-20&ascsubtag=COM_CLICK_ID%7C65b92750-7601-11eb-b62f-bf326e8dccd0%7Cdtp
$6 dollars
these are the cables I used
https://www.amazon.com/gp/product/B07WD6DKN5/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Pls verify the link? I’m getting Amazon Garage Delivery service.
Thanks.
https://www.amazon.com/dp/B00ISLNSH0/ref=cm_sw_r_cp_apa_fabc_0226J4STMMF47X29X583?_encoding=UTF8&psc=1
amazon# CY Micro USB Female to 2 Micro USB Male Splitter Extension Charge Cable for Galaxy S5 i9600 S4 I9500 Note2 N7100 S3 I9300 S2 9100
oops!!
Which micro usb y cable do you use?
This one
https://www.amazon.com/dp/B017OPOG58?ref=ppx_pop_mob_ap_share
This looks like the same one that @JBRADY76 has but a different brand.
bought a generic one from Amazon
UCEC Dual Micro USB Splitter Charge Cable Power up to Two Micro USB Devices at Once from a Single USB Port (2pack)
UCEC
I have this splitter connected to the light socket and connected to two V3’s
Welcome to the Wyze User Community Forum @randblue73! :man_raising_hand:
That is interesting. Can you share why you chose a splitter that can’t plug into the USB A port on the Light Socket and only one of the microUSB plugs on the cam pigtails. How do you get that thing to work? There has to be a minimum of two more adapters or cords to use it.
