I would like to see a one part cylinder door contact. I envision a 3/8”cylindrical x 1 1/2” deep plunger/ button style wifi door contact switch. You drill a 3/8” hole in door jam and push this in frame. Door shuts and contact
makes. A few company’s make this style, but its hidden and could work with any
swing open style door. See example in attached photo.
I like the suggestion.
In the meantime, I saw this on Etsy which is used with Wyze Contact Sensors…
Here is a Youtube Video of it
Might be an option
Thank you very much! Thats exactly what I need. Great find!
Thanks Rob
Note: No trees were harmed during the sending of this message, but a large number of electrons were really inconvenienced.
My Pleasure, hope it works out. However, the V2 Sensors will be different, not sure if the same enclosure will work. I am sure someone will come up with a similar enclosure. But wanted to make sure you knew, especially if you upgrade to the V2 Sensors.
Hidden is nice for not advertising who you use, adds a tiny bit more work for someone looking to defeat it.
I like the fit and finish look with the hidden aspect as an added feature
