NOTE: I don’t have a Cam Pan, so I don’t know if this would work for that too. Trial and error!
Step 1ne: Buy a USB Power Bank
Step 2wo: Plug the camera’s power cable into the bank
Step 3hree: Plug the bank into a wall adapter so that it’ll always be charging
Step 4our: Press the “on” button on the bank if needed
And done! The v2 doesn’t seem to need that much power from the bank, so I’d say that using the one I got from walmart, It’ll run for a long time. Though, I only have it set up this way so that if the power goes off for a sec, it’ll reconnect a bit quicker, since I’m just using the cam as a Sense bridge.
Yes this has been discussed a long time but there seems to be a gray area as to which batteries really provide pass-through charging properly. It is rarely in the specs.
Hmm, then I guess the user should test their power bank and see if it can charge and provide power at the same time…
Or you could let people know which one you are using.
I lost the box to it, but I’ll post a pic of it. Got it at Walmart around 2-3 years ago, and it looks like this
Also, the info on the back of it reads:
Model: 16WMS126
Input:DC5V 1500mA
Output:2100mA Total
Capacity: 5000_+_50mAh,18.5Wh
Manufactured by
SHEN ZHEN DNS INDUSTRIES CO.,LTD
MADE IN CHINA
1724A
I’ll post a photo of the info on the back once I can get a good one since my phone refuses to focus on it.
One thing to consider when charging that pack all the time is will it overcharge the battery?
Or does it have a charge controller that will properly control the charge, if that battery is getting very warm it likely has a cheap charging circuit. This could be dangerous and a fire hazard.
Something to be aware of
This is what you should be looking for on Amazon:
“5V UPS battery backup uninterrupted power supply”
They come in all shapes, sizes, and price ranges, starting around $20
They are designed to plug in full time and only switch to batteries during a power outage.
You can use one for your modem and routers as well. These have been around for ages and should not present a fire hazard.
Probably a product Wyze should offer.
Y’know what? Wyze should make one of those!
Doubles as a space heater.
Yeah, or a white noise machine if they put some fans on it.
The bank stays nice and cool. Though I do understand your concerns!
I meant the UPS (and referenced indirectly the real live Wyze space heater project).
wait Wyze is really making a space heater??? pog!
