Can you please add sign in.
What I mean is when you go to an xfinity hot spot it connects to the wifi but then it requires a login and password and then a code is texted to your phone to enter in to the log in site. We need to be able to endter that info in to the wyze cam when it connects to their wifi. It shouldn’t be to hard with the app.
[Mod Note]:Your request was moved to this category for better visibility in order for you to receive help from the forum community.
@pieman16 is referring to a captured portal for wifi access. The login is on the hotspot and is required to access the wifi. Wyze doesn’t support this but there is a wishlist item for it.
If the web portal only needs the login “Once” then is remembered by the hotspot.
Maybe spoofing the MAC ID of camera on smartphone to do the initial login with the hotspot,
then let camera connect after that. This would only work if the login is a one-time thing though…
Don’t think that would work because Xfinity first requires a user and password then it wants a code it texts to your phone to activate. That’s why I think it needs to be in the app.
Here is how Xfinity does it.
You connect to their hot spot
It sends you to their landing page and wants your user name and password.
The next page it wants the code they sent your phone.
Once you put that code it sent you in it logs you on to their Wi-Fi.
