Wyzecam floodlight v2 mounting orientation
I’m thinking of replacing an older camera with a Wyzecam Flood V2 that would need to be mounted on a horizontal (ceiling) surface rather than vertical (wall), basically just inside a pretty deep garage doorway at the top facing out. The Existing camera has a ceiling mount with 180 degree swivel, but I’m just not sure if the Wyze camera and floods will rotate far enough to give me good coverage down the driveway. Also, I’d be using the optional plugin mounting bracket since there is an outlet already in place. Any thoughts if this will work?
Here is an Image of an individual who mounted theirs horizontally.
Perfect. Thanks!
