So that thread really didn’t seem to answer the question the OP had.
My issue is similar. I want to mount it under an eave/soffit, where I am replacing an old flood light. If I mount it HORIZONTALLY, with the hardware out of the box, correctly, not upside down, the angle of the camera is such that it is almost pointing DIRECTLY at the ground. If I try to tilt it up, at the angle of the mount, it will not go up any farther.
I would guess there HAS to be a round 4" junction box that is “L” shaped, but I don’t see anything like that. Any suggestions? I have read you can mount it upside down, but I see no way in the app/device interface to invert the camera view.
Another issue I am having is the wiring I have it connected to was from the old floodlight setup. That wiring is connected to an ‘On/Off’ switch in the house. If I turn it ‘Off’, the light or the camera does not work. If I turn the switch ‘On’, the camera works, but the light stays on continually. Am I missing something with the motion detection and the floodlight coming on and off? I do not see anywhere in the settings to adjust this. I also have a regular front porch light that is motion detected and it turns off after a certain period of time, even with the switch in the ‘On’ position.
It does, but it only swivels so far up based the max distance it will swivel. if I turn the cam upside down, then it will swivel up high enough to capture the driveway, etc. But then the image is upside down.
The only solution I can think of is some type of “L-shaped” junction box that will allow me to connect the hardwire, then connect the camera at the other end of the “L” to point the direction it needs to
Support told me the same thing but there is no such setting for the v2 camera.
All that is under Advanced Settings is 'record to microsd card;, ‘manage sdcard’, ‘night vision mode’, ‘camera status light’, ‘show timestamp’, 'show wyze logo, ‘record sound’ and ‘synch time’
I want to mount it flush/horizontally where the black tape is currently holding it in place. However, the arm is currently extended up as much as it will go. If i mount it flush on the horizontal surface, then the cam itself points at the ground.
I CAN rotate it 180° but then the image is upside down as well, and i see no settings to flip it. Ty
