Wyze Web Live rearranging camara views
Wyze Web Live can you rearrage the camaras in view?
Currently, there is no way to rearrange your cameras via LiveView
The order aligns to how you have them laid out in your App.
How, then, do you rearrange them in the App?
Click and hold on the camera and move up or down.
as @Habib stated, tap and hold then drag
Didn’t mean to “steal your thunder” :wink: just wanted the OP to resolve the issue ASAP.
Very helpful. I did not know this. :slightly_smiling_face:
Seems obvious now that I know! :smiley:
Not at all. I like the assist. :slight_smile:
Been hectic on my side so any help is appreciated
Good to know as I feel a bit reluctant to give advice when the OP is asking different person.
@habib, it’s all appreciated!
Glad to be of help!
Advice and options are always welcomed. Getting an answer or options quickly is always a good thing. Don’t hesitate, I will not be offended. :wink:
:+1:
If you’re talking about the list of cams that are aĺl either live or not, yes. Just hold your finger on one cam and move it up or down. Then you can do another, and so on.
Thanks! That is a good thing to know.
You’re welcome. I hope that’s what you were looking for.
Thank you all for your recommendations and comments.
