Is there a way to change the order in which cameras appear while using web view? I have a few cameras going up the length of my driveway (long driveway) and I’d like to be able to set them in order from the street back to the house. I know how on the app but doesn’t appear to be an option on web view. At least not that I can find.
Welcome to the Wyze Forum @jkuhley
Unfortunately there is not.
It is annotated on the below Wishlist item for the WebView. Take a moment to review and give the Wishlist Item a vote.
yes. drag and drop windows… maybe put the order in by dragging and dropping in the camera selection tab
Not for Web View. You’re referring to the app. In Web View, you can’t even select which cameras to view, let alone reorder them.
web view… subscription service. yes, you can select which cameras to view
Yes, to an extent, but that’s not what I meant.
If you have inactive cameras, you can’t exclude them. Web View will keep on trying to connect to them and slowing things down. What would be great is to tell Web View which cameras you only want to be included in the cameras available to view.
I posted here as the wish list page asks to check for duplicates before posting. your feature was similar.
