Wyze Watch Battery Notification
Hello all!
Is there any way to get a notification when my Wyze Watch’s battery is low? I hate going to check the time to find my watch is dead.
If that is not possible, I hope it could be added in the future.
Thanks,
FlocktimusPrime
there is a notification (on the watch) @ 20% & 10%
Really? Does it cause a vibration? I have never seen it. Is it something I need to turn on in settings somewhere?
Yes, there’s a vibration when the notification comes in. I believe it’s an automatic setting. I don’t recall seeing a place to turn on
I got a low battery notification once, the very first time my battery was low. Since then I get no low-battery notifications at all and frequently look down to a dead battery. Very frustrating.
I would rather get a notification and vibration when battery is low.
I have the Wyze Watch 47, and have also had the issue of not receiving any “low battery” notifications. Instead I look down at my watch and notice it has died. This has happened multiple times to me and I hope they add a fix/update soon!
Pretty please… just add a small RED DOT at the corner of the display once the charge dips below 20%. Easy to implement and would be very effective at informing the user that the watch needs some TLC.
