I connect to my outlook at work through my samsung android. I believe that’s the same GMail app that the watch has, but can someone confirm?
I doubt anyone can confirm as nobody has one yet. Well maybe a beta tester?
Not sure this has entered beta yet, and if so testers are under specific NDAs so you may not get an answer that way.
If this works similar to the Wyze Band, you’ll be able to toggle on notifications from any apps that will display on the watch.
well played.
