Wyze Watch 47mm Reboot
I’ve seen posts that state the same issue I’m having … which is that my Wyze Watch 47mm will occasionally start vibrating incessantly for about 30 seconds … and then reboot. A few time daily. Though I’ve seen numerous posts on this annoying issue, I haven’t seen any posted solutions. Does anyone know if this is just a “normal” issue with the 47, or flawed without a solution (FWS) like some other Wyze product issues (such as static/hissing with the Wyze Cam V3 live feed). Thanks.
Mine does this occasionally. It normally happens when there is an event, or sorts, then it starts and does not stop. I press he button to try and stop it, but in the end it does reboot.
Although it happens in frequently to me, it is not the norm and I have not found a solution yet.
I submit a log and then contact Wyze, providing them the log as well.
Mine seems to do it every day and yesterday it did it twice in about 20 minutes time. Now whether it does it more often and I don’t have the watch actually on my wrist who knows. I guess my question is if people are having this issue with the watch, what is Wyze doing about it?
