Wyze Watch 44mm Firmware Beta Test 4/15/2021
FIRMWARE VERSION:
  • 0.3.68
WHAT’S NEW:
  • Fixed a bug that caused the Wyze logo to display for too long after an update
  • Fixed a bug that caused the watch to reboot
After enrolling my Wyze Watch 44 into the beta yesterday the firmware update seems to have caused an issue. I had the following message on the phone:
core data missing,
please connect the wyze app to upgrade.
ver:0.3.68
device no.6C38
I submitted log id:192572 and opened a ticket 1191609
After removing the watch from the app and attempting to reconnect the watch only shows the Wyze logo and will not re-add.
There are many posts on issues with the Wyze watch 44. Fix notifications please. awkward and unreliable.
Any idea if they are working for a fix for the incorrect weather coding?
The current high/low matches the tomorrow high/low right now on the watch 44. It’s not a coincidence, it’s all the time. So either they coded the today high/low with the info for tomorrow’s high/low in error, or vice versa with tomorrow’s high/low being coded with the info for the today high/low.
https://forums.wyze.com/t/wyze-watch-44-current-temperature-wrong/176911/10?u=towelkingdom
Is Wyze going to support the 44mm watch for how long?
They removed the 44mm from the website.
