Brief: It damages walls and carpets, misses all of the perimeters, and is yet one more needy device in your home. It gets stuck all the time and mis-docks and runs dead. It’s very buggy.
Does not vacuum within 3~4 inches of any wall or table leg. After a while a gray unvacuumed line will emerge. (“Vacuums as good as a three year old”)
Unit sends you notifications 24 hours a day, even if you have turned notifications off in the app.
Unit will bash and chip and scratch your baseboards.
Unit leaves permanent black tire tracks on light colored carpets, especially if they are damp.
Unit gets stuck in infinite loops and will wear your carpet raw, or will wear a circle in the carpet.
Unit will leave permanent-tracks around all of your furniture, because it travels the same path around furniture every day.
Unit gets stuck under toe-kicks a lot. Can’t seem to understand a standard American 4" high toe-kick is lower than the LIDAR head.
When unit runs out of power and gets lost it doesn’t send its last known location, so you have to go hunting it down every day. “Where’s my robot?” is a constant waste of time.
It will sometimes circle endlessly until the battery dies. It will be full of the carpet it has ripped up and swallowed over the course of an hour. Or, it may recharge and spend all night devouring your carpet.
Technical Support is worthless and unresponsive.
You cannot purchase replacement filters.
EXAMPLES:
Ruins your carpets:
Ruins your baseboards:
Permanently embosses your carpet:
Scuffs your walls and furniture:
Gets stuck under furniture. Oblivious to the height of the LIDAR on top:
Gets stuck in normal 4" American toe-kicks:
Fails to clean within 3" to 4" of any wall or furniture:
