Sorry twice. Sorry you are having problems. And sorry, but there’s not enough information to offer a solution. Error 90 means in most general terms, “communications error”. This could mean a lot of things to you.
Tell us a little more. What have you tried? Let me get you started. I say this so, you will think of doing this as a routine. Wyze cameras “like” being turned off and back on hmm, I’s say 1 a week at least. Some of us do it daily. (No we don’t run around unplugging and plugging them back in. We use WiFi adapter plugs that allow us to create a schedule.
And its good for you network to restart your WiFi router. Doing so will correct some connection errors that are intermittent before they become even known to you. Think of it as preventive medicine, for your network. How often? At least once a month, some of us do it more often. Its a little inconvenience waiting for things to pop back up, but its better than waiting for a problem then trying to find a way to get everything working again.
Now, let’s ask about that Problem-Wyze. When you swapped it, did you also replace the cable and power adapter? Maybe not? Try using a spare one, and setting it up some place where you can check on it. Like watching the light on and off? Not working? Can you add it again to your network? Not working, eh? Then no, When you plug power in to the back, does the light come and and stay yellow? If so, its sort of stuck in a boot up operation. You might try reloading a 1 step backwards version of the firmware. Google Wyze Firmware install, and it will help. Pay close attention to the details in the instructions. Every step is critical.
Check back in. If not me, there will be someone else here to help move you along in your troubleshooting. (I am long winded, sorry about that too.)
Do not need to put the answers to these questions here. But want to get you thinking. Don’t answer, just look at your stuff there. What router do you have? Look it up on the Internet. In its specs, how many Internet connected devices will your router allow you to connect to it? What’s the number? Don’t need to post it here. And count all of the things around your house that could be connected to the Internet. Everything, like phones, ipad, laptops that are not on the network all the time, but sometimes,. iRoomba, all your cameras, Ring doorbell? Everything. Is the router device number, I asked about near that number? (Again, no need to tell us the number,)
