PUD Smart Rewards Program accepts only a BPA-qualified thermostat. I can see wyze thermostat has all those features which need for the BPA-qualification, just wanted to check if it BPA approved. Currently, wyze is not in the list of approved devices on county’s website
Welcome to the Wyze community @rakesh.motghare!
The thermostat isn’t currently BPA certified. I’m not sure if there’s a timeline for this. @Chuan might know. You might want to add this to the #wishlist!
As you have pointed out Chaun would be the best person to answer, but I believe usually for products to be certified for things like that they have to be out for a year or so, then there is actual data they can go off of for certification.
