Greetings all!
My HVAC does not have C wire and as you can see from the current config I have a 4 wire setup. I’ve gone ahead and bought a 24v adaptor to provide power and according to those instructions it says to add one leg to the RC and the other to the C. With that said as I’ve scanned trough the forums i’ve seen mixed responses. In my current config am I to assume the Red is RH? does it matter? any help would be greatly apprecaited.
I’ve included instruction from the adapter I bought which also makes me ask this, When i install the Wyze thermostat do i say i have W, Y, G, C, RC and RH? thank again all.
