Has anyone successfully connected their Wyze thermostat to a Modine Hot Dawg? If so, which connections were used from the board to the thermostat? Thanks
It seems to be working correctly now:
Wire connections =
W(board) to W1(thermostat)
R(board) to Rc(thermostat)
C(board) to C(thermostat)
Welcome to the Wyze community @mattrnewell!
It looks like you only have 2 wires going to the thermostat. Did you use the adapter or a third wire?
I added an additional wire from C to C… I’d additionally like to figure out if I can connect G and just have the fan run… It may be useful during the summer months…
I’d leave G off until wyze fixes the firmware on the wyze to not call the fan as soon as the heat is called on gas furnaces.
