Maybe I over tighten my electical connections, but loose connections are bad… I discovered the wyze switches are a little fragile. Thankfully only broke one out of 10 total switches, so I guess that’s not too bad, but I dialed down the torque a little on the rest of them.
Installed a sub-panel and ran 8 seperate circuits for controlling my light display (between November and January). Been using the wyze outdoor timers, where I have reliable wifi coverage outside and they work great. Now my entire display, 16 circuits total, will be completely controllable via my phone. Will make scheduling easy, and turning on areas for repairs or whatever will be super simple.
