I am replacing an existing single pole switch because I wanted a timer and use several other Wyze devices.
I connected the line and load correctly, and pulled a neutral from the box(5 gang box). Turned on the breaker and no flashing light. I followed the install and switched the load and line, though I tested the hot, and still no flash. I have two of these switches so I tried on another switch and same result.
I disconnected and installed a standard single pole switch and it worked as expected..
Any suggestions ?
