I had the switch installed & had a blue flashing light on the switch. Before I could go to the App to finish the installation my wife turned the switch. Now, all that happens is the bulb connected to that switch flashes & no flashing light on the switch. I have tried holding the switch on for 20 sec. to do a reset & that did not work. Any ideas about what I should do next?
Thanks, Mike
Try flipping the circuit breaker off then on.
I did that all ready bulb continues to flash.
Is it a wyze bulb? Or a “dumb” light bulb that’s flashing?
Dumb LED bulb
