Just installed the Wyze Switch (one of the lucky ones to find at HD) right next to my front door which has a Wyze Lock. I love the switch but would love it much better if the additional controls supported trash mode on the lock. Only options are lock/unlock.
Did you already have that cover plate or did you buy it for that install?
I already had it, but I bought it when I installed the smart tp link switch I was previously using.
Don’t mind my ignorance. ![]()
What is Trash Mode?
Light switch looks good.
I found out this configuration is not easy to find.
Thanks - that explains it. Guess I should get a Wyze Lock. ![]()
Next thing to order…
First, I’m Jealous! Now help me understand what’s happening. The lock has a trash mode, but are you saying since you’ve connected the switch to the lock (I guess you double tap switch to open lock or something?) that the lock overrides or doesn’t activate trash mode? Tbh, I’ve never used trash mode and have forgotten how it works, but I know it’s there… ![]()
The switch has additional controls for rules. What I’m wanting is the option to activate trash mode using one of the additional controls.
I get it now.
