I’m running two separate Wyze Sprinkler Controllers at two separate residences and they seem to be working relatively well. I recently went into a preset Default Schedule I have set up for my 6 zones.
Once you set up a Default Schedule within the App you CANNOT adjust or edit the watering times for each zone individually.
i.e., Your running all 6 zones at 30 minutes and you notice your garden zone is getting too much water so you want to cut that zone back to 15 minutes and leave the other 5 zones untouched. YOU CANNOT DO THIS.
You must completely delete the Default Schedule and start from scratch setting up every single zone.
Its not a huge coding workload to provide watering time adjustments within the Default Schedule.
Please review for next update.
